66 Mustang with Heavy Vibration
Old Oct 25, 2017 | 01:47 AM
66Classic's Avatar
66Classic
Default 66 Mustang with Heavy Vibration
Hello everyone, I recently purchased a 66 mustang that has had a 90-91 302 engine installed. There is some very heavy vibration felt in the car at 2000rpm and higher - even while in neutral. I've been told not to drive the vehicle as this shaking will damage the engine. Ofcourse the seller who sold me the car never mentioned this issue and I just thought it was how a old classic feels. After doing some research I have found out that either there is a wrong harmonic balancer or flywheel installed. In the worst case I may have a bad engine. I have gathered all the serial numbers off the engine (F16E) the serial number off the harmonic balancer (E4TE-A3A) and the flywheel (RF-E1ZR6380.) I also attached pictures of the serial numbers just in case I am not reading them correctly lol
If anyone has any knowledge about this vibration and can help that would be so greatly appreciated. Im hoping the harmonic balancer or flywheel is not correct and that I don't have an engine rebuild ahead of me. Any ideas?
Attached Thumbnails 66 Mustang with Heavy Vibration-66-mustang-2.jpg   66 Mustang with Heavy Vibration-66-mustang-flywheel.jpg   66 Mustang with Heavy Vibration-66-mustang-serial.jpg   66 Mustang with Heavy Vibration-66-mustang-transmission.jpg   66 Mustang with Heavy Vibration-engine.jpg
Old Oct 25, 2017 | 10:21 AM
Gun Jam's Avatar
Gun Jam
a 91 engine should use the 50oz weight.
1) check that the damper wheel has a key installed under it to properly align it
2) check that its using 50oz and the weight is installed proper...some race dampers use removable weights.
3) is that a t5 trans? what tag is that?
4) what motor mounts are you using? There needs to be proper rubber isolation between the frame and the engine provided by the motor mount if its steel on steel its going to suck.
Old Oct 25, 2017 | 02:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Steel on Steel or Polyurethane instead of rubber with both create vibrations. PU not as bad as just steel but it will be pretty bad on a classic car.
If it turns out to be the dampner and you replace it, if the problem goes away, you may still want to drop the pan and inspect the rod and main bearing for odd wear. You can cause excessive wear at either end of your crank from an imbalance depending on how bad it was and for how long it was driven like that.
