Change rear end, or change out driven gear?
Old Apr 15, 2018 | 04:33 AM
  #21
Worth1's Avatar
Worth1
Originally Posted by Gun Jam
No I was using the old math provided by Imp :/
I've never had to count revs to guess rear end size but I knew there was a trick with the open setups
Ya, think if it this way, if you have both wheels off the ground and you turn 1 wheel 1 revolution and come up with 2, then you hold that wheel in place and turn the other wheel 1 revolution it will be another 2. So no different than doubling your first count. If you're alone it's actually easier to jack up one wheel, mark the inside of the wheel with chalk, mark the driveshaft, then turn the driveshaft until the wheel does 1 rev. then double it.
I probably should say use a jack stand and chock the wheels on the ground, just incase.
mxz71@hotmail.com
Apr 3, 2010 05:34 PM
trooper1241
Jul 23, 2008 11:35 AM
black88gt
Nov 20, 2006 10:12 PM
wine_maker
Oct 30, 2006 07:08 PM
TreCool626
Sep 19, 2003 11:05 PM
