67 mustang 429 cj c6 to t56 swap help
Hey guys, i have a 67 mustang coupe with a 429 cj from a 70 ford tornio in it. Currently i have a c6 in It but I want to put a t56 6 speed transmission. I am trying to do it on somewhat of a budget as i am only 17 and only have one job that doesnt pay that much. I was looking at a t56 from a gm lt1 or other brands lke chevy because they are significantly cheaper and more readily available than the ford variation of the t56. If yall could help me out that would be great. Thank you!!!
Then the clutch linkage/throwout bearing system must be done. Maybe use early Mustang mechanical linkage, maybe later cable-type easier to fit up? Clutch swing pedal has to be added under the dash. Which type depends on linkage type. Or, last resort, a "juice" clutch release using a master and slave cylinders like on Ford F-150s or Explorers, around 1995, '96. Either need a clutch pedal for them.
Gotta get a flywheel to fit 429 big block, make certain of the proper balance-weight on it. Clutch type used must be compatible with the flywheel. Finally, if you still have automatic-transmission rear gear ratio, very low numerically, like 2.69, unless the manual trans. has a quite low first gear ratio (that is, high numerically, like 3 to one first gear), it will be very "boggy" from a standstill.
How much work of this nature have you done? Are you up to it?
I am pretty mechanically inclined, ive been working on cars for a couple hears and have people to help me with stuff that i cant do. I know thay id need to raise the transmission tunnel about 2 inches to fit the t56 but i assumed when i started this that i would have to modify something when instarted. And why would i want to avoid the hydraulic clutch?
Cable-release system, like Fox bodies used is pretty foolproof, but still inferior to mechanical. The cable rolls-up on a semi-circle quadrant under the dash. Stock quads are plastic; first thing to replace with an aftermarket metal one. Since cables can only PULL, not push, the throwout fork has to work kind of backwards, with it's throw-out pushing the bearing in the CENTER of the fork, the pivot at far end from the cable-attach. Mechanical release PUSHES the fork, the pivot is between the outside end and the throwout end.
Jskeezy84
Sep 8, 2015 01:40 AM
tjmartin
Aug 15, 2013 06:51 PM
Silverblade
Apr 18, 2009 12:19 AM
