Starting Issue with my 1968
Old May 19, 2020 | 01:16 PM
stp12345's Avatar
stp12345
Default Starting Issue with my 1968
Hoping someone could help me trouble shoot a starting issue I'm having. Basically I need to pour a bit of gas into carb to get it to fire up. If its run for awhile I can restart no problem, but if it sits over night or for a few hours doesn't seem to want to start without the gas poured in. Runs perfectly fine otherwise.
I replaced the fuel filter and it was pretty gummed up (this was just a maintenance thing, not that I thought it was the issue) . I'm going to check the fuel pump, and accelerator pump tonight to see if both are working fine. Anyone have any other suggestions on what might be the cause? thank you!
Old May 19, 2020 | 05:48 PM
Gun Jam's Avatar
Gun Jam
check the choke first and then the accelerator pump.
The choke should be closed 80% of the way about when cold. if you placed a pencil down the carb and closed the choke plate so it held the pencil...thats about the size of the gap you want.
ironwarrior
Aug 21, 2016 12:00 PM
JohnHunt
Nov 5, 2009 05:32 PM
XXC
Jan 15, 2008 04:15 PM
blahman20
Aug 17, 2007 05:22 PM
Craig67
Jul 3, 2006 05:45 AM
