Sniper throttle extender in 1968
Old May 29, 2022 | 08:17 PM
Brad1968's Avatar
Brad1968
Default Sniper throttle extender in 1968
Hi been lurking here trying to learn all I can. I finally have something I need to ask about my car. 1968 mustang, 289. Originally had a 2 barrel and was converted to a 4 barrel Holley at some point. The original owner did the threaded rod heim.joint thing to connect the stock throttle pedal to the Holley 4 barrel. I just did a motor rebuild and sniper EFI system. It runs great but like many others I find the intitial tip on tough. I installed the throttle extender bracket but the threaded rod heim.joint not will not work. Once I readjusted the length to reach the hole on the extender the gas pedal hits the floor and about 75 percent throttle.
Old May 29, 2022 | 08:19 PM
Brad1968's Avatar
Brad1968
Sorry hit the wrong button and submitted before I was done. Does anyone have anyone have any idea how to connect to this and still have full travel? Do I need to do a cable conversion.? It's a c4 auto with the kickdown cable attached to the pedal if thst helps. Thanks
68dustin
Mar 11, 2009 10:44 AM
SJs 66coupe
Nov 21, 2008 05:38 PM
freefallpat
Dec 18, 2007 06:51 PM
Guitylerham
Sep 10, 2007 03:11 PM
PAINTEDPONY
Mar 14, 2007 07:11 PM
