1966 soft brakes issue when started
Old Aug 24, 2022 | 09:27 PM
Mikey99's Avatar
Mikey99
Default 1966 soft brakes issue when started
So ive gone ahead and bled everything. No air in the lines. I have one of those cheap brass combination valves for front disc and rear drums. There seems to be a leak from the brake light warning sensor. Brakes are okay when pumped when car is off but it completely depresses when the car is on. Could the proportioning valve be the culprit or should i be looking elsewhere. I know these cheap chinese proportioning valves are notorious for failing. Any recommendations?
Attached Thumbnails 1966 soft brakes issue when started-762ab0b3-f3e7-4e40-819b-baff94d2cac2.jpeg
Old Aug 24, 2022 | 11:45 PM
Mostang66's Avatar
Mostang66
Did you just do an upgrade to the brake system? If so, explain what you have done so far.
dlensing
Mar 26, 2014 05:25 PM
lincr06
Jun 4, 2010 03:53 PM
farkedup
Apr 14, 2008 07:58 PM
JimboGT01
Aug 5, 2007 02:51 PM
DJ19895.0
May 17, 2006 03:53 PM
