Passenger side Turn signal stuck on.. wont flash any ideas?
Old Mar 15, 2025 | 05:49 PM
Gun Jam's Avatar
Gun Jam
Default Passenger side Turn signal stuck on.. wont flash any ideas?
Hello
The passenger side turn signal wont flash. When signal is on the rear light comes on but stays lit and wont flash. The front amber is out
This quit working about a day ago. I did install some wiring for a fan controller but it should not have caused any turn signal issues... but its at least a coincidence.
1) all lights work, The ambers up front light up when park light switch is set
2) brake lights work
3) tail lights work
4) DS signal works
5) I believe the blinker switch is okay because it does cause the PS side tail light to illuminate but not flash DS works as expected.
6) flasher relay maybe okay it at least works with DS. Im assuming its the same contacts it only has 2 wires going to it...
7) switching amber lights from DS to PS does not change things
The only notable issue besides it not flashing is the PS amber light is not stuck on like the tail light it is out (but works when park lights are set)
Any idea.
Thanks!
Old May 5, 2025 | 12:10 PM
Nosara's Avatar
Nosara
Default Check
Check the ground and bulb. Start simple.
QUOTE=Gun Jam;8741713]Hello
3) tail lights work
4) DS signal works
Any idea.
Thanks![/QUOTE]
Chroniix
Dec 7, 2018 04:08 PM
machI1970
Apr 20, 2010 07:47 AM
rneely2111
Jan 10, 2009 02:14 AM
unit91
Apr 1, 2008 07:11 PM
