light Problems
Old Apr 1, 2008 | 05:30 PM
unit91's Avatar
unit91
Default light Problems
When I have the rightturn signal on and hit the brakes, the right turn signal light turns to a steady on light. Also, when I put the car in reverse the backup lights work fine but when I turn the left or rght turn signal on the backup lights flash (both of them) and there are no turn signal lights working. I have the instrument cluster out - would that cause any of this? I traced wiring in the rear and did find and repair a broken ground wire so now both my brake lights work, but all the other probems are still there. I'm glad I stopped drinking a long time ago
Old Apr 1, 2008 | 06:22 PM
LCC's Avatar
LCC
Default RE: light Problems
Seeing that the reverse lights are not part of the turn signal/brake system, I would say you have an issue with a ground in the back of the car..
Old Apr 1, 2008 | 07:06 PM
unit91's Avatar
unit91
Sorry, but I'm not following you. If there was a bad ground, wouldn't I be having problems with the lights when they are used separately? All lights work properly as long as there is no combination of lights being used. Once the combination hits, the lights that used to work start not to work.
Old Apr 1, 2008 | 07:11 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Most problems like this can be traced to the turn siganl switch. The back up lights don't go through there so that is a mistery. I would say put you dash back in to see if that is affecting it and go from there.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
philster0306
Aug 10, 2015 11:33 AM
