roof gutter replacement
Old Nov 8, 2005 | 12:05 PM
351foxstang's Avatar
351foxstang
Default roof gutter replacement
does anyone offer the rain trim that goes around the door of a 67' coupe?
thanks,carl
Old Nov 8, 2005 | 12:09 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: roof gutter replacement
Do a search for "Drip rail molding"
Old Nov 8, 2005 | 12:13 PM
351foxstang
thanks,
i made a mistake, i mean the actual metal that the trim is attached to.
carl
Old Nov 8, 2005 | 12:17 PM
gta289's Avatar
gta289
as far as that goes not that i know of.... you might find a wrecked car and cut the old off...but that sounds hard to do, i havent seen any drip rail metal that has rusted, which is weird, but that would be your best bet
Old Nov 8, 2005 | 12:45 PM
351foxstang
thanks,
i just called like every yard within 100 miles of me. nothing. i think it would look horrible without them... i can try to make my own, the whole section is not rusted out only about 6-8" on the ends. all i really need is something there so that i could glue the molding to it and no one would notice.
thanks again,
carl
Old Nov 8, 2005 | 01:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
You are going to have to cut out the rust, and weld it. Be sure to POR 15 it before and afterwards. Then just grind it down to match the rest of the rail.
Old Nov 8, 2005 | 03:21 PM
351foxstang
thanks guys,
this will most certainly be fun.
carl
Old Nov 9, 2005 | 12:10 AM
pak133's Avatar
pak133
Contact Dan from coloradomustang.com he'll cut anything off of any car. I know, he's done it for me.
Old Nov 15, 2005 | 10:22 AM
ivanr77's Avatar
ivanr77
the rails do rust out, water can get trapped underneath the sealer...or the sealer gets old and cracked and water gets in there causing the rails to rust... Soaring offered one of the best ideas. Cutting the rails out wouldn't be the best move as you could be tapping into the structure of the roof, although i'm making it sound worse than it is.
a picture or two would be nice to help us give you better advice.
Old Nov 15, 2005 | 11:45 AM
351foxstang
here are a couple pics of the spots on each side. the rust is only on the front sections. i was thinking sandblast the entire length of each side and weld in some square tubing to build up the strength.
thanks for your help,
carl
[IMG]local://upfiles/19521/5B33E1EA6BEB451E82D0D14AC123CF6D.jpg[/IMG]
[IMG]local://upfiles/19521/0669896CC6214984B9D68F64744B1974.jpg[/IMG]
