paint questions
Old Nov 12, 2005 | 07:28 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: paint questions
ORIGINAL: jrrhd73must
I used semi flat black and did the underside myself. As for POR for the the floor pans there is Central GA mustangs here that takes Undercoating to the floor pans. The guys theory is that it protects them and isulates them against sound. It was the first I heard of it.
Undercoating may be OK for a few years on the inside of the car, but after a few years it tends to turn loose and trap water. By using seam seal, you will keep any water from coming up from the outside. Using undecoating on the outside bottom is not a good idea, in that it will definitely trap moisture. If you want sound proofing, just use an underlayment under the carpet.
Old Nov 13, 2005 | 09:26 AM
gta289's Avatar
gta289
IMO when i redid the whole underside of my car, i first did a chemical strip to the entire thing, and became friends with a dye grinder (hands and all) it took about a month to scrap and grind to a bare metal finish but once i prep the metal with ppg metal prep, i sparyed rustoleum to the whole thing, than three coats of clear, followed by 5 coats of red oxide. the biggest thing is to make sure the tack welds are completely covered, because they rust the quikest. as for the engine compartment i suggest going to NPD for the correct semi gloss paint. they IMO have the best matching factory paint to date, and i did my engine comaprtment in it and looks perfect. i think all in all expect to pay about 150 bucks for paint for the whole car, remember the more coats of paint the better
Old Nov 13, 2005 | 12:51 PM
BillyBobJoe's Avatar
BillyBobJoe
thanks guys. I already looked up the paint on NPD, and I may soon be ordering that. I' leave the flat black on as a primer so that the green/teal doesnt come back through. As for the floor, i saw NPD has Red Oxide also so i plan to order that too and eventually get around to painting that. thanks again guys
Old Nov 13, 2005 | 03:55 PM
my 67's Avatar
my 67
I also will need to redo the underside of my car next Spring, what is and where can I get this seam seal? Why use this Red Oxide. Is it somehting special. I am fairly new to the restoring part of this, my brother always does this.
Old Nov 13, 2005 | 04:22 PM
gta289's Avatar
gta289
red oxide isnt special but it does IMO a better job at protecting raw metal against rust, if applied right. You can get seam sealer at Eastwood, but is used for gas tanks, and cowls. The undersides on these cars can be protected very well if you use the prossess i talked about earlier. Dont be afraid to put a lot of rust-oleum under your car, the more the better. Construstion companies use rustoleum for the i-beam welds so they dont rust, so if it hold multiple storys up, i think it can hold a little water(thats its purpose) after the rust oleum i sugest a high tempature clear coat (duplicolor makes 500 degree) so the paint wont fade or peel from exhaust temps, and finally get as many of the cans of ,black,red oxide, gi joe green you can get and spray generously. (NOTE: red oxide is for 1965-1970 san jose cars, black was dearborn; GI joe green was 71 and up) sorry concourse note couldnt help myself but whatever tickels your fancey, just remember, doing something to the underside is better than leaving all that old undercoating on and making a little problem a big one
Old Nov 13, 2005 | 05:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
No, son....Seam seal is not only used for gas tanks and cowels. It is used for every seam you want to seal, therefore the name "seam seal." It works perfectly on the floor pans to seal those seams, before applying the red oxide and paint.
Old Nov 13, 2005 | 09:18 PM
BillyBobJoe
wait a tic, black is for Dearborn? my 69er's a Dearborn. lol, i don't want to screw something else up.
Old Nov 13, 2005 | 10:51 PM
garywwelch's Avatar
garywwelch
I noticed in some of the post everyone is saying go for the flat black in the engine bay. Is there a problem if I use a gloss black?
Gary
Old Nov 14, 2005 | 08:54 AM
gta289's Avatar
gta289
ORIGINAL: BillyBobJoe
yes dearborn cars all recieved black, san jose red oxide, but you can do either if you choose, i was mearly pointing out a concourse note just in case thats what your going for
Old Nov 14, 2005 | 08:57 AM
gta289's Avatar
gta289
ORIGINAL: garywwelch
Gary
it makes no diiference what you use....hell you could use purple if you wanted, but were stating the "correct" color is low gloss, which has just enough shine to it to keep it easy for you to clean. ive seen many mustangs owners that have used higher gloss black, and like i said, nothing wrong with it, its all in what you want to do. thats the whole point of this hobby, freedom to express how you like your car(s) to look. if you want to go for custom, or restomod, or even to your own liking dont worry about the correct color, the only ones that need to be worried about the correct color, is the enthusiasts, or the sad depressing concourse freaks out there....who would want to live that life anyhow?
