cam
summit racing web site is very good...type in specs and then give you different types of parts that will go in your stang and also gives a brief notes about the part...i when i bought my stang it had elderbrock intake and carb so i went with elderbrock cam...ground shipping is also free...any thing that is under 150lbs...
CCA-CL31-238-3 is a good cam for a 289 using a stock converter and springs. Since you have an intake and headers, this would give you good driveability and more power, plus that sound you want.
If you want to get everything, like timing chain, springs, retainers, locks, in addition to the cam and lifters use this number. CCA-K31238-3
If I were doing a daily driver type 289, this is what I would put in it. Much bigger and you are going to need gears, lose converter(if auto). Unless you want to change the heads and you have a manual trans, then you can go a bit more. A lager cam moves the powerband up in rpm leaving little to no power under 3000 rpm, where a street car spends most of its life.
If you want to do a full build with aftermarket heads and change other things on it, let me know. You dont have to follow exactly, or even take my advice, but overcamming sucks. It sounds mean but doesnt go anywhere.
Heres the specs on that cam.
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,300-5,600 RPM
Intake Duration 050 inch Lift: 218
Exhaust Duration 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 270
Advertised Duration: 262 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.493
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.500
Valve Lift with Factory Rocker Arm Ratio: 0.493 int./0.500 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Grind Number: FS XE262H-10
Direct link to summit's site. Copy paste if it doesnt show as a link.
http://store.summitracing.com/partde...1&autoview=sku
junior04
Sep 28, 2015 10:53 AM
