shifting weeeeird
Old Nov 29, 2005 | 05:29 PM
gta289's Avatar
gta289
Default shifting weeeeird
I had a weird situation happen to me just the other day. I was in the old silver bullet, taking it out and around the block, and kinda got on it a little, and right when it was ready to hit into third, it boahged down, and died!!!! It only did it once, i got it going, and drove without having it die, only now when it shifted into third, it felt almost like it was missing the gears, but gets in there. I drove it yesterday, and it did it again, so im gonna go home and check the vacumme modulator to see if its clogged or something, if not what do you guys think. I dont think its a carb problem, so what could it be? Thanks for the help guys
Old Nov 29, 2005 | 05:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: shifting weeeeird
ORIGINAL: gta289
Has it happened since then? It does sound like a vacuum leak.
Old Nov 29, 2005 | 05:54 PM
gta289's Avatar
gta289
im gonna go home in a delacate few, and give her another drive..... man if the tranny is f@#ked, im gonna cry, cause i really dont want to tear it out.... sigh.. no if it does, those modualtors get clogged easy i know that, but if its not, im gonna yell at someone, and more than likely it will be your fault somehow
Old Nov 29, 2005 | 08:59 PM
hutchamatic's Avatar
hutchamatic
Sounds like the intermidiate band did not release and probably burnt the high gear clutches.
Old Nov 30, 2005 | 04:22 PM
gta289's Avatar
gta289
ok nothing to worry about, i went home and pulled the modulator off, and sure as s@#t it was clogged real bad. I just took a round brush with metal brissels on the ends and cleaned it up good. I took it around the block once again, and that was the problem. I wonder why it clogged so bad in the first place, my motor doesnt even have 5,000 miles on it lol
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Mustangmalo
Sep 6, 2015 05:22 PM
