Wheels
Old Nov 30, 2005 | 10:41 PM
6mustang6's Avatar
6mustang6
Default Wheels
I just bought the GT bullitt wheels for my 67 vert. I need to get the adapters and I would like to know what size the bolt hub circle is. I can get the kit from pep boys for much cheaper then a mustang vendor. I just dont know the specs of them.
Old Dec 1, 2005 | 09:59 AM
Fastback Guy's Avatar
Fastback Guy
Default RE: Wheels
If you are asking for the bolt pattern size, it's 5 x 4.5
Old Dec 1, 2005 | 10:27 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Wheels
Thanks FastbackGuy. I was trying to figure out what a bolt hub circle was. I almost scratch my head raw.....
Old Dec 1, 2005 | 11:28 AM
dodgestang's Avatar
dodgestang
Default RE: Wheels
Remember....when fitting late model wheels to get the right backspacing you need bolt on wheel spacers. I wasn't aware that Pep-Boys was carrying 1 inch 1.25 inch or 1.5 inch bolt on wheel spacers....you can't just stack multiple 1/4 spacers or 1/2 spacers etc in and then bolt your wheel up this will be very very very dangerous. Not that you would but I just wanted to make that point anyway.
Old Dec 1, 2005 | 12:00 PM
Fastback Guy
Default RE: Wheels
Good point as well dodgestang. I don't like spacers either. If I were going to buy Bullitts for my car, I'd suggest buying the ones for the '67 so you don't have to use spacers. That said, my front wheels have a .20" spacer on them. It was one of those things where BAER said that they'd work and Boyd Coddington said they'd work but when all was said and done, they wouldn't quite work. and I didn't want to send either back so I went with the spacer. No problems yet.
Old Dec 1, 2005 | 12:33 PM
rollin66's Avatar
rollin66
Default RE: Wheels
Just curious....what are those spacers running at Pep Boys ?
Old Dec 1, 2005 | 01:12 PM
Dan66's Avatar
Dan66
Default RE: Wheels
ORIGINAL: rollin66
I'm pretty sure he's mistaken and that PepBoys is not selling the thick bolt-on spacers needed for these late-model wheels. They typically have the unsafe "shim" spacers.
Old Dec 1, 2005 | 08:46 PM
6mustang6's Avatar
6mustang6
Default RE: Wheels
What i was talking about was the actual adapter kit. I tried on the wheels today and they fit except in the front where they rub where the spindle bolts onto the A-arm or whatever the spindle connects to up there. I know the back spacing of these wheels are prob. 5.72. What size spacer do i need, and i can only put them on the front, or should i go all the way around? Thanks guys.
Old Dec 1, 2005 | 11:31 PM
dodgestang's Avatar
dodgestang
Default RE: Wheels
You should install the adaptors in the front and rear.
If the wheels are 17s....a 1 inch kit is just right
If they are 16s you need a 1.25 kit
Old Dec 2, 2005 | 07:47 PM
6mustang6's Avatar
6mustang6
Default RE: Wheels
They are 17" I will need to have longer studs right?
