engine code
Old Dec 2, 2005 | 03:01 PM
mustangnewbe's Avatar
mustangnewbe
Default engine code
I'm not sure where the engine in my mustang came from. Where is the code usually stamped?
Old Dec 2, 2005 | 03:21 PM
jrrhd73must's Avatar
jrrhd73must
Default RE: engine code
I am not sure what you are looking for? Are you looking for what engine came in the car? Where the car was assembled?
Old Dec 2, 2005 | 05:02 PM
mustangnewbe
I was looking for the number on the engine. I know that the engine that is currently in the car is not the original one
Old Dec 2, 2005 | 05:18 PM
jrrhd73must
If you post the VIN code we can tell you what was supposed to be in the car. There is not really a good way to tell if that is the exact engine that cam in the car.
Old Dec 2, 2005 | 06:02 PM
mustangnewbe
Well, shouldn't there be a number on the block that identifies the engine...what I really need to know is if the 302 that is in the car is a BOSS 302 or not
Old Dec 3, 2005 | 12:15 AM
Silver Ponys's Avatar
Silver Ponys
If its a Boss it will have cleveland heads a high rise manifold cast aluminum or chrome valve covers it should also have a balancer that is about 3.5 inches wide. part numbers for the block are C9ze or D0ZE this number should be right above the starter cast into the block
Old Dec 3, 2005 | 08:28 AM
Soaring's Avatar
Soaring
I ♥ Acer
Take the starter out, and the number will be stamped behind it on the block.
Old Dec 3, 2005 | 10:53 AM
69FECoupe's Avatar
69FECoupe
If your valve covers have six bolts, it's not a Boss. If they have eight, it could be a Boss or a Cleveland or a conversion.
Old Dec 4, 2005 | 09:06 AM
gta289's Avatar
gta289
stop the confusion!!! lol real quik way to tell if its a boss from the vin number is if the 5th letter in the vin reads a "G" if it doesnt than its not one....geez just reading all those post gave me a headache[&:]
Old Dec 4, 2005 | 06:01 PM
69FECoupe's Avatar
69FECoupe
The fifth letter in the VIN will tell you what it was originally equipped with, not what may be between the shock towers now. For someone who doesn't know the difference between a Boss and a standard 302 by sight, counting the valve cover bolts is the quickest way to tell. Hell, if someone checked the fifth number in my VIN, they would say my 390 was a 200ci straight six.
