Handling upgrades
Old Dec 12, 2005 | 07:44 PM
6mustang6's Avatar
6mustang6
Default Handling upgrades
Ok, I just want to get everyones opiniom on handling upgrades for these dinosours. WHat is a good cheap upgrade i can do? And if i decided on getting a new flaming river steering box, What is the length of the shaft for a 66 289 auto? with manual steering.
Old Dec 12, 2005 | 08:24 PM
redstallion's Avatar
redstallion
Default RE: Handling upgrades
larger sway bars, quality shocks, and wider tires are simple things that make a big difference...
i don't know much about the steering box...
Old Dec 12, 2005 | 10:28 PM
69mach1377's Avatar
69mach1377
Polyurethane bushings are a must...
Old Dec 13, 2005 | 11:01 AM
jrrhd73must's Avatar
jrrhd73must
ORIGINAL: 69mach1377
With a rear sway bar - car won't drive the same.
Old Dec 13, 2005 | 06:54 PM
6mustang6's Avatar
6mustang6
I was thinking about sway bars, and the shelby drop. And maybe new performance springs on the front.
Old Dec 14, 2005 | 12:18 AM
69mach1377's Avatar
69mach1377
ORIGINAL: jrrhd73must
That is exactly the point...stock handling sucks. You can 'tune' the sway bars with adjustable end links to get what you want. What you don't want is mushy rubbery ride. Poly every where you can and use good gas shocks.
Old Dec 14, 2005 | 12:21 AM
6mustang6's Avatar
6mustang6
im getting a suspension upgrade kit, that comes with front and rear sway bars(with poly bushings) and KYB shocks. and im getting subframe connectors, and a new export brace, and doing the shelby drop. Do you think it'll be better?
Old Dec 14, 2005 | 01:10 AM
Fastback Guy's Avatar
Fastback Guy
6mustang6,
You're car will absolutely be better.
Old Dec 14, 2005 | 10:07 AM
jrrhd73must
ORIGINAL: Fastback Guy
6mustang6,
You won't realize it is the same car....
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
