Adjusting carburetor
Old Dec 17, 2005 | 10:17 PM
Ilikeponys's Avatar
Ilikeponys
Default Adjusting carburetor
Ok well I thought I had a exhaust leak cause I can smeel fumes in the cab but I took it to a place and they said it was just running really rich. It runs fine, and I can floor it and it doesnt bog at all and it starts up fine. But it does smoke alot. So What I am wondering if how do I adjust it. I have never worked on a carburetor before but I know that there are adjusting screws. Its a 2 barrel 289. So how do I do it? Is there a certain amoun of turns I back the screw out? And how do I know it adjusted properly?
thanks
Old Dec 18, 2005 | 01:01 AM
69mach1377's Avatar
69mach1377
Default RE: Adjusting carburetor
Use a vacuum gage, turn idle mix screws in all the way (it might stumble a bit), turn screws out a half turn, then adjust them both until you have max vacuum.
Old Dec 18, 2005 | 04:00 AM
mlitz's Avatar
mlitz
ORIGINAL: 69mach1377
what are u talking about???????[sm=WTFsgign.gif]
turn the mix screws all the way is (tell its snug not tight) then 2.5 times then adjust from there, it will mess with your idle so fix that to......
Old Dec 18, 2005 | 06:06 PM
lClutchl's Avatar
lClutchl
never mind...
Old Dec 24, 2005 | 06:48 PM
65fastback351's Avatar
65fastback351
testing for maximum vacuum is the way to do it less you have an oxygen sensor jerry rigged to your headers. if turning the screws all the way in doesn't make your car stall out then your carb needs to be rebuilt or just slap on a good old holley dp
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
