351 non roller block question
Old Dec 23, 2005 | 05:52 PM
65fastback351's Avatar
65fastback351
Default 351 non roller block question
now i know they sell retro roller lifters for a non roller block. but those lifters just keep each other aligned using the dog bone at top. if you took the lifter retainers and the spider off a roller block or bought one...and tapped retaining holes for the spider in the block, if you could use regular roller lifters, or will the roller camshaft be so small that the regular lifters fall into the block because the retro lifters are taller than regular rollers. would appreciate any help
Old Dec 23, 2005 | 08:06 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 351 non roller block question
go to the junk yard and find a 5.0 mustang get the cam and lifters and spider assembly same firing order as 351 and will work in ur block
Old Dec 23, 2005 | 08:07 PM
65fastback351
it's a 74 block im pretty sure they have a different firing order
Old Dec 23, 2005 | 09:56 PM
BillyBobJoe's Avatar
BillyBobJoe
i dunno if this will help but the firing order on the 351 stayed the same from 69 when it debuted to at least 74 since mine is a 74
Old Dec 23, 2005 | 11:17 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the firing order is the same for all 351 the 5.0 ho is the same as the 351windsor i have vintage cars and late models i have read article and looked at them
[IMG]local://upfiles/23144/686FDB7A3D674DAA98C17B0AC3EB56C9.jpg[/IMG]
[IMG]local://upfiles/23144/E33B8FC648724073ABD044BA7CF83526.jpg[/IMG]
[IMG]local://upfiles/23144/EE1A8985C80640E4929453510BB7AA1A.jpg[/IMG]
[IMG]local://upfiles/23144/F795E551ED7E484BAFD4857937150E52.jpg[/IMG]
[IMG]local://upfiles/23144/671A029DD0644DE29EE20CCE5E1A1B27.jpg[/IMG]
Old Dec 24, 2005 | 01:41 AM
351foxstang's Avatar
351foxstang
the 351w firing order has never changed.
im trying to find out if we can use the spider thingy for roller lifters on our 351w blocks. i was told by someone that if i were to use it and the lifters from a roller block that it would need a "small base circle cam". i am thinking that he thought i meant using 302 lifters. after the holiday i will go to the junkyard and see if there is a difference between the 302 and 351w roller lifters.
carl
Old Dec 24, 2005 | 02:15 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes u can u just have to drill the holes in the block to hold the spider down!
Old Dec 24, 2005 | 12:24 PM
65fastback351
thats good then...cause retro lifters are 400 bucks...and regular lifters are like 150. im so glad i joined this forum
Old Dec 24, 2005 | 06:39 PM
65fastback351
also...im planning on getting afr185cc heads so would i need the same length push rod as a 5.8 roller?
Old Dec 24, 2005 | 08:20 PM
69mach1377's Avatar
69mach1377
I thought that a roller block has deeper/taller lifter bores, hence the difference in lifter length....so the retrofit kit accounted for that difference. Better make sure...
uedlose
Sep 30, 2015 08:01 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
96stang3.8
Sep 10, 2015 06:42 AM
Sep 8, 2015 05:21 PM
