Run synthetic?
Old Dec 18, 2005 | 09:35 AM
gta289's Avatar
gta289
Default Run synthetic?
i was wondering if it would hrut my motor any to run synthetic oil in it after using conventional for the motors birth up to now. The motor has only 5-6k miles on it and ive read and heard it will not hurt the motor any. Any suggestions would help
Old Dec 18, 2005 | 01:40 PM
6mustang6's Avatar
6mustang6
Default RE: Run synthetic?
Now why in the world would that hurt the engine? It WANTS That stuff.
Old Dec 19, 2005 | 01:14 AM
pootscratch89's Avatar
pootscratch89
I purchased a 390 for my truck a couple of years ago, and the engine builder said to wait until you have at least 10-12K miles on it. If you don't wait, the engine doesn't have enough time to "break-in". Changing to synthetic too early will prevent proper "break-in".
Vern
Old Dec 19, 2005 | 01:23 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
engines need break in time for the rings and flat tappet cams synthetic is super silck so must use convential for around the thousand miles then switch!roller cams need no break in
Old Dec 19, 2005 | 04:30 AM
waxyourboard's Avatar
waxyourboard
The break in on the rings is the most important thing... Without a proper break in, the rings wont seal right on the cylinder walls, because not enough metal was shaved to make it a perfect fit. Using synthetic during the initial break in prevents a lot more friction, and the rings never quite set in
Old Dec 19, 2005 | 11:10 AM
jrrhd73must's Avatar
jrrhd73must
Agreed however most gas engines only need 1500 miles to break in. A diesel needs 5000 miles.
Also, corvettes and vipers now come with synthetic and they don't have a break in period.
Definitely run synthetic. Just make sure that it is really synthetic. All oils that are LABLED synthetic are not. You redlines, mobil 1, oil like that are. Your pensoils, quaker states, shells are not regardless of what they are labled. I can explain further if anyone is interested.
Old Dec 19, 2005 | 12:49 PM
gta289's Avatar
gta289
yeah i would like to know whats the best to run in the engine, i run red line in the rear end, and royal purple in my trans, but im really unsure of what to use when i comes to the engine. Cost isnt a factor, i already baby the hell out of that car as it is so
Old Dec 19, 2005 | 01:33 PM
jrrhd73must
Obviously by my signature I prefer Amsoil. I think redline, royal purple and Mobil 1 are fine.
The biggest thing is to use a lab created synthetic. There are many oils out there that say they are synthetic - shell, quaker state, etc that are just further filtered dyno oil.
http://www.amsoil.com/lit/g2156.pdf Here is a white paper comparing multiple oils on the market.
Old Dec 19, 2005 | 02:37 PM
Riven02's Avatar
Riven02
I use synthetic is all my cars. I prefer Mobil 1 because it is easy to find.
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
