65 coupe floor pan question???
i am planing to install floor pans and toe pans, pretty much everything exept the tunnell...when cuttiing out floor pans, is there any thing attach to floor pans like fuel lines, any electrical lines or anything that can be possibly cut by accident??? thank you for any responses....
the best thing to do is to get up under your car and look at everythingso you will know exactly whats under there. the main things are fuel lines brake lines and the emergency brake
ORIGINAL: dcohen
good day, if my memory is correct your you have no electrical to worry about , those wire`s run thru your door gutters. Your brake line runs thru your trans tunnel, your fuel line runs from the rear passenger side right frame rail up to the torque box, that will be an issue. If your gonna do it your self invest in some good seam sealer, measure twice cut once.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
uberstang1
Sep 20, 2015 06:42 PM
