Gears
Old Dec 29, 2005 | 11:07 PM
Mustang9668's Avatar
Mustang9668
Default Gears
Hey My 68 has the 2.79 rear gear and I was wondering if putting in a 3.00 or 3.25 gear would put a lot of strain on the engine while I was on the interstate???? Would it be better to just leave the 2.79 gear and put the money into a locking differntial??? Thanks
Old Dec 29, 2005 | 11:32 PM
69mach1377's Avatar
69mach1377
Default RE: Gears
3.25 would liven it up on the street without much highway penalty. 3.00 would not be noticable...
Old Dec 30, 2005 | 12:46 AM
valley firearms's Avatar
valley firearms
Default RE: Gears
You can run lower gears with an AOD and still have decent gas mileage with no more strain on your engine. You engine should be able to handle lower gears anyway.
Old Dec 31, 2005 | 04:04 AM
Mustang9668
Default RE: Gears
Hey thanks for the replys....an aod is out of my price range for now. I'm pretty well set on 3.25's then.
Old Dec 31, 2005 | 10:38 AM
slickman's Avatar
slickman
Default RE: Gears
Just an FYI, if your going to go through all that work, go with a set of 3:55's. I just did mine and its fine on the highway as long as you keep it at 55 - 65 you're good.
Old Jan 1, 2006 | 02:04 AM
6mustang6's Avatar
6mustang6
Default RE: Gears
Ok, Im sorry, but 55-65 on the highway is grandma speeds. IT'S A MUSTANG. I wouldn't do anything to it, that would cause that. I like to cruise the highway around 75-85.
Old Jan 2, 2006 | 02:20 AM
rollin66's Avatar
rollin66
Default RE: Gears
ORIGINAL: Mustang9668
Check out my database and see if the info there helps... best of all it's real world
Old Jan 3, 2006 | 04:17 AM
Mustang9668
Default RE: Gears
I agree. If i'm on the interstate i'm going to be hittin 70-85 most all of the time so i prob wont go any further than 3.25.
Old Jan 3, 2006 | 04:35 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Gears
is this top speed were talking here or just comfortable rpm's for the engine?
Old Jan 3, 2006 | 10:10 PM
Mustang9668
Default RE: Gears
This is for comfortable engine rpm. I want some more get up and go down low but I don't want to spin too many rpm while on the interstate doing 75.
