Gears
Old Jan 3, 2006 | 10:17 PM
6mustang6's Avatar
6mustang6
Default RE: Gears
Yeah, i am also thinking about the 3.25 gears. I believe they would be perfect for our cars.
Old Jan 5, 2006 | 05:56 PM
slickman's Avatar
slickman
Default RE: Gears
To each his own.. If your driving highway allot, then go with 3:25 or 3:00 gears.. I myself like the light to light responce with 3:55's.. Below is a compairson of 3:25's and 3:55's at 60, 65 and 70 mph. The tire size used for this was 225 / 45 - 17
60 MPH
3:25 = 2579 RPM
3:55 = 2817 RPM
65 MPH
3:25 = 2795 RPM
3:55 = 3050 RPM
70 MPH
3:25 = 3010
3:55 = 3287
ORIGINAL: 6mustang6
Just an FYI, if your going to go through all that work, go with a set of 3:55's. I just did mine and its fine on the highway as long as you keep it at 55 - 65 you're good.
Ok, Im sorry, but 55-65 on the highway is grandma speeds. IT'S A MUSTANG. I wouldn't do anything to it, that would cause that. I like to cruise the highway around 75-85.
Old Jan 5, 2006 | 10:46 PM
Mustang9668's Avatar
Mustang9668
Default RE: Gears
Hey what kind of tranny was used to get those numbers? I have a C-4 in mine. I figured their would be more of a difference in rpm then that. Thanks for the posts guys this is really helpful.
Old Jan 5, 2006 | 10:54 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Gears
it looks like the 3.25 is the most balanced choice.
Old Jan 6, 2006 | 01:12 PM
slickman's Avatar
slickman
Default RE: Gears
Okay, here are the links so you can play with the numbers and see what best fits your needs..
RPM Calulator
Tire Height Chart
ORIGINAL: Mustang9668
Old Jan 6, 2006 | 11:55 PM
Mustang9668
Default RE: Gears
Well guys I've pretty much decided on 3.25's for the simple reason that I have a 20 minute ride back and forth to college everyday and that they will give me enough pep to satisfy me for now. Thanks for all of the replys. I appreciate all of the help!!!!!!!!!!!![sm=hail.gif]
Old Jan 7, 2006 | 12:29 AM
351foxstang's Avatar
351foxstang
Default RE: Gears
sorry for the retarded question but i haven't had a daily driver car in a couple years. what is a "comfortable" rpm range to be running on the highway? i'm with you guys, i like the 75-85 mph range for highway speeds. sorry for the question but im used to my diesel powered f-250 and she doesnt like going much over 2200 rpm.
thanks,
carl
Old Jan 7, 2006 | 03:04 PM
69mach1377's Avatar
69mach1377
Default RE: Gears
Any tranny that is not an overdrive has a 1:1 final drive...
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
