289 Performance Package??
Old Dec 30, 2005 | 11:30 AM
slickman's Avatar
slickman
Default 289 Performance Package??
I'm thinking about installing a performace package like one from Edelbrock. What are some thoughts about this and Recommendations? I'm just looking to increase the compression to around 9.5 to 1 or so and get a little more kick in the rear feeling. Not looking for a big HP monster, just a nice growl.. Right now its stock with a Edelbrock performer intake and a Holly 600 (which I hate) carb..
Old Dec 30, 2005 | 12:52 PM
daver's Avatar
daver
Default RE: 289 Performance Package??
thats the same set up i have on mine right now.... what gears do you have in the rear?, that might pick it up a bit. I know, my holly runs rich right now
Old Dec 30, 2005 | 02:42 PM
Dan66's Avatar
Dan66
ORIGINAL: slickman
Believe it or not, you've got too much carb. (I'm assuming you've got a 289 or 302, right?) You need no more than a 500 cfm carburetor - and even that's more than what Ford put on back in the day. The smaller carb will give you much more low-end torque (i.e. off the line performance).
Save a few headaches and switch over to an Edelbrock carb while you're at it.
Old Dec 30, 2005 | 04:03 PM
69boss429's Avatar
69boss429
If you are having carb problems i.e. to rich,bogging,etc. You might try this before investing in another carb,set your distributor advance curve for a 38 degree total at 2500 rpm and 10 to 12 degrees initial advance. Then check your power valve,if your engine has ever backfired through the carb you probobly blew out the diaphram. Be sure to replace it with one marked 10.5 to 12.5 unless your running a lumpy cam that pulls low vaccum(12 in. or less).Check the jets,a stock 1850 Holley( 600cfm ) is usually a little fat out of the box and going down 2 sizes should clear up your problem. (60 to 62 primary jets,63 to 64 secondary or equiv. metering plate)Finally,a modern pointless ignition like a MSD with a 6A box works wonders.
Old Dec 30, 2005 | 11:41 PM
slickman's Avatar
slickman
Hi Guys!! Ok, the rear I just finished rebuilding (my first one). I replaced all the bearing and seals including the axle bearings. The gears I installed are Richmond 3:55's and I also setup a Diff locker from Summit (PN PWT-1810-LR). I think its called Posi-Trax, it has no clutches. Its like a ratachet kind of setup.
As to the Carb, yep... I have had problems with backfires and it does bog at times. I plan on replacing the Carb with a Edelbrock soon and maybe a set of new heads from them too... I hate Holley, never thought they were any good...
Old Dec 31, 2005 | 12:10 AM
slickman's Avatar
slickman
I must say, I love you stang!!!
ORIGINAL: Dan66
ORIGINAL: slickman
Old Dec 31, 2005 | 12:42 PM
69boss429's Avatar
69boss429
Learning how to tune your Holley carb would be a whole lot less expensive than buying an Edelbrock carb.Holley carbs are used on practicaly every drag race car out there.Why,because they work well when properly adjusted.I have a pair of them on my Boss 429,and my son has a 600 on his 68 coupe with a 302 and 5 speed trans. Tune up kits are inexpensive ! http://www.1969boss429.com
Dokilar
15
Oct 16, 2015 08:13 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
