1968 6cyl rear end
Old Jan 7, 2006 | 07:24 PM
skeetshooter's Avatar
skeetshooter
Default 1968 6cyl rear end
I installed front disc brakes from a 1976 Granada but would now like to change the rear end to tge same 5 lug bolt pattern.
What donor cars will interchange with my mustang rear end? I'm new at this so please be patient
Old Jan 7, 2006 | 07:59 PM
Jaye's Avatar
Jaye
Default RE: 1968 6cyl rear end
that Grenada rear wil fit n your car coolsweet dude drops in!! bud o m brother did that was real sweet
Old Jan 16, 2006 | 01:02 AM
67CarolinaCoupe's Avatar
67CarolinaCoupe
anyone have info on this?
Are there any adaptors to change 4 lug to 5 lug on the rear? I'm in the process of upgrading to Granda brakes in the front and would like 5 lugs all around.... but I'm not planning on dropping in a larger engine so a larger rear end is not a must.
Old Jan 16, 2006 | 10:52 PM
bryanvw61's Avatar
bryanvw61
you'll need a 8" or 9" out of a 67 or 68 i believe. search ford 9 inch rear end in google, there are some sites out there that list the widths of all the rears, however the spring perches may be different... of course one you do the rear to get that 5 lug, you'll have to do the driveshaft, i know its gotta be lenghtened, and thats the question i have on my 66
Old Jan 16, 2006 | 11:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Just go to a junk yard and pick up a complete rear end with axle and brakes, etc. from a 1977-1980 Lincoln Versailles.
Old Jan 16, 2006 | 11:40 PM
6mustang6's Avatar
6mustang6
I was at a pull apart the other day, and just so happened to walk by a mercury something, which i believe would have worked right? anyway, i decided to look at it, and someone had already swipped the spindles from it. Dang
Old Jan 17, 2006 | 08:33 PM
67CarolinaCoupe
what about just buying the axles?
I don't really want to replace the whole rear end.
Thanks for the info already provided.
Old Jan 18, 2006 | 04:08 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Here is a link to what you need. It is everything you wanted to know about 9 inch ford rearends. I'm not saying that you need a 9 inch, an 8 inch will work just fine. At the very bottom on the page is a table that lists axle widths. These will be the same for 8 inch or 9 inch in what ever car they came in. Long story short, the table says that all 67-70 rearends are the same width. Anything in that year range will work from a Comet Cougar Mustang or Fairlane. Hope that helps. Here is the link http://www.maliburacing.com/ford_9_i..._nine_inch.htm Scrap the idea of changing axles. you need acomplete housing. The 6 banger rear ends are junk.
mtgldr
Feb 3, 2024 09:00 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
