Rear Differential ?
Old Jan 11, 2006 | 12:55 AM
6t7pony's Avatar
6t7pony
Default Rear Differential ?
Just put a new one in my 67.. went from a 2.79 to a 3.40.....now...my problem ..
Got a C4 with a 302 but it seems like the RPMs are alot higher at 50MPH then it was.....
also the speedometer is reading way off...like going 50 but showing 70,, What can I do to fix this problem or was the gear in the rear to much for a C4 tranny,
Thanks for any info.
NEW TO THE SITE<<GLAD TO BE A MEMBER
Corey
Old Jan 11, 2006 | 01:16 AM
BillyBobJoe's Avatar
BillyBobJoe
Default RE: Rear Differential ?
welcome to the site, you may have to change your speedo gear, i dunno since I'm still a newb in the technical department but check out this site and some other replies
there might be a calculator or something to help
http://www.allfordmustangs.com/AFM_T...rs/index.shtml
Old Jan 11, 2006 | 02:39 AM
valley firearms's Avatar
valley firearms
I know this won't help any, but I'd be doing some hella smokey burnouts with the lower gears. Otherwise, change the gear in your tranny that drives your speedo.
Old Jan 11, 2006 | 08:29 AM
gta289's Avatar
gta289
you will need to do some reasearch before buying the new gear, becasue unfortunatly, there is limitations to the amount of gears for the speedo. You may have to go with a 3.25 speedo gear, or possibly a 3.55, which if i remember correctly, the 3.25 is pink and 3.55 yellow.
Old Jan 11, 2006 | 12:53 PM
daver's Avatar
daver
the reason your speedo is reading high is because with the lower gears,it takes more turns of the driveshaft to turn the drive axles, therefore it will turn the speedo gear faster in the tranny and force your speedo to read alot faster. The gear in your transmission that turns your speedo is calibrated to work with your stock rearend gears, the 2.79's. You will have to get a gear that works with your gears and tire size. i have a 68 and 3.73 gears and 14 inch wheels and my speedo reads about 88 when im actually doin 65 mph at 3500 RPM. Dont worry, you dont have to much gear for your C4, Ive seen plenty more.
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
