Rain problem...
Old Jan 19, 2006 | 03:04 PM
Dan66Stang's Avatar
Dan66Stang
Default Rain problem...
Every time it rains over night, the next morning my car acts like it doesn't wanna crank up like it normally does. My cars a daily driver, and it usually runs great every day, but when it rains it acts up. Do any of you know whats causing this? Moisture in the dist. cap? Thanks
Old Jan 19, 2006 | 04:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Rain problem...
That was my first thought Dan. Next time, pop the cap and see if there is some moisture in there. Either wipe it out with a cloth, or use your air compressor to blow it dry.
Old Jan 19, 2006 | 05:43 PM
dcohen's Avatar
dcohen
yup
Old Jan 19, 2006 | 05:48 PM
bryanvw61's Avatar
bryanvw61
thats one sweet ride you got there dan!
Old Jan 19, 2006 | 06:21 PM
Dan66Stang's Avatar
Dan66Stang
Thanks bryan, and thanks to everyone else for the replies. I thought that was the problem, I just wasn't sure.
Old Jan 19, 2006 | 06:25 PM
redstallion's Avatar
redstallion
if you still have points and a condenser, consider replacing them with a pertronix kit
My car is also a DD and moisture has never prevented my car from running since I've had the pertronix...the basic one only costs about $60 and that's the one i'm using
Old Jan 19, 2006 | 06:38 PM
Dan66Stang's Avatar
Dan66Stang
ORIGINAL: redstallion
Yea, I've been wanting to upgrade to an electronic kit for a while.
Old Jan 19, 2006 | 06:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
The pertronix my help some, but the problem usually isn't with water on the points, it's water on the contact points on the underside of the dizzy cap that usually causes the misfiring. You still use a rotor with the pertronix module. I think I would smear a very thin coating of clear silicone around the dizzy where the plug wires go into the top. Then smear a thin coating on the lip of the cap where it makes contact (clamps down) to the dizzy and let it dry before putting the cap back on. I know this may sound like shade tree stuff, but it might work to help keep the moisture out.
Old Jan 19, 2006 | 07:22 PM
dcohen's Avatar
dcohen
YOU LEAVE YOUR MUSTANG OUT IN THE RAIN?!?!?! HOW COULD YOU!
nah, just kiddin with ya. If i were you i would get a car cover for your stang. Maybe that would solve the problem
Old Jan 19, 2006 | 08:51 PM
Dan66Stang's Avatar
Dan66Stang
ORIGINAL: dcohen
Gee, give me a break here, I'm in college.... I have a cover but some times I just forget about it.
