14" or 15" rims
Old Jan 21, 2006 | 02:13 PM
redmach's Avatar
redmach
Default 14" or 15" rims
Hi all, My 69 fastback currently has 14" slotted mags with BFG T/A's mounted
on them. (see gallery) These do not have any clearcoat on them and oxidize very fast, like a week after I polish them. I have been cruising the web looking for a new set with a nice polished finish and clearcoat. I have seen them in only 15" sizes minimum. My other dream wheels are the American Racing Torque Thrusts with the gray spokes, aka
" bullit " rims. These come in 14" sizes. Do I run into any issues just by bolting on 15" rims and tires besides the speedo not being accurate? I still have several months before I can drive it on these salted roads. I have 4 wheel drum brakes if that makes a difference.
Thanks.
Old Jan 21, 2006 | 07:07 PM
bryanvw61's Avatar
bryanvw61
Default RE: 14" or 15" rims
as for running a bigger rim, the only concern is braking since the little bit larger rim has a little more mass to stop, not a big deal. as for the speedo, when you put the 15inch rims on it, you'll get tires with a lower profile, which should match close to the 14s circumference, inturn now really affecting the speedo
Old Jan 21, 2006 | 07:31 PM
Magiarn71's Avatar
Magiarn71
Use this little calc to see what you need for a new tire compared to what you are running now.
http://www.miata.net/garage/tirecalc.html
(Yeah, its from Miata, I found it using a tire calc search a long time ago.....)
Old Jan 22, 2006 | 11:53 PM
slickman's Avatar
slickman
Go with 17"....
Old Jan 23, 2006 | 02:33 AM
SeanoStang's Avatar
SeanoStang
id say 15s cuz thats what i like on all classic muscle cars.
Old Jan 23, 2006 | 11:22 AM
Dan66's Avatar
Dan66
Step up to the 15s. I just put a set on my '66 a couple months ago and am very pleased. They fill up the wheel well much better. Much more visually appealing...
[IMG]local://upfiles/13087/7180DD41E31245D5AABC81AB72C50417.jpg[/IMG]
[IMG]local://upfiles/13087/BC062612556A4883B11398F216B96D06.jpg[/IMG]
Old Jan 23, 2006 | 05:45 PM
baddog671's Avatar
baddog671
What size tires are those on the wheels Dan? Look good
Old Jan 23, 2006 | 06:35 PM
Dan66's Avatar
Dan66
Thanks, Nicolas.
They're 215/60/15 BFGs on all four corners (on 15x7 wheels). No clearance problems except in severe dips. I hear the backs touch every now and then. I'll probably roll the rears...
Old Jan 23, 2006 | 09:07 PM
redmach's Avatar
redmach
those do look good. I can't get used to the 17" and larger on the classic cars. Personally, I don't like the low profile look, the more side wall the better.......
I also like the torque thrust wheels with the gray. Yours fill the well real nice. I am going
to check into which cars came with 14 and which came with 15"
Old Jan 23, 2006 | 09:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here are my 14's. I could go 15's, but why? The car came with 14's. There is a reason for that.[sm=bling.gif]
