Spring Questions... bounce bounce
Old Jan 25, 2006 | 11:44 AM
bryanvw61's Avatar
bryanvw61
Default Spring Questions... bounce bounce
I want 1 inch drop springs for my mustang to go with my global west control arms, and now that the drivers side floor is done, its on to the front end.
The car came with some new stock V8 springs from mustangs unlimited, i'll have to check the number, but they are the stiffest.
What I need to know is if the mustang springs are more progressivly wound or normal. Will i ruin the ride by cutting them, or if i should just save up for the drop coils, because I know from expereince some drop springs are just less coils, but the same wire.
Also, what is the difference in the weight between the I6 and a 302? I don't want to change the springs twice and the I6 is going to keep my rolling while I rebuild the V8.
Old Jan 25, 2006 | 12:20 PM
slickman's Avatar
slickman
Default RE: Spring Questions... bounce bounce
The dropped springs are about $100 for the set however, if you're going from a I6 to a 302, you're going tp need to mod more than just the springs.
Old Jan 25, 2006 | 02:50 PM
bryanvw61's Avatar
bryanvw61
oh i know that, while i put it back together i'm collectiing parts to do it... have versaille spindles and disc brakes, dual bowl master cylinder, 8 inch rear end, t5 in pieces, extra driveshaft and V8 yoke needing to be made from 51" to 52" for the 8", the 302 of course...lol
and i know there is the question on the steering with the V8... someday i'll buy a setup out of a V8, but i know the I6 will work for the short term.
but i guess i just don't want to do the same thing twice, like springs, although they are easy enough to swap out, i'd like to get the v8 setup in to begin with.
Old Jan 25, 2006 | 07:04 PM
bryanvw61's Avatar
bryanvw61
i guess i should ask the question in much simpler terms...lol
has anyone ever compared regualr coils to drop coils?
were there the same amount of windings?
was the space between the coils windings uniform?
was the space between the 2 coils windings the same just fewer coils on the drop spring?
was the wire the same thickness?
Old Jan 25, 2006 | 07:27 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Put one inch drop maier racing springs on my 67. As I recall the number of coils was the same. The unloaded spring height was shorter and the wire size was fatter. The space between the coils was less while unloaded and they were not progressively wound (same spacing top to bottom)
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
Gene K
Oct 21, 2015 11:37 PM
mungodrums
Sep 28, 2015 10:54 PM
