carb rebuild...
Old Jan 27, 2006 | 03:01 AM
351foxstang's Avatar
351foxstang
Default carb rebuild...
hi guys,
how difficult is it to rebuild a holley carb? i figured it would be alot cheaper to pick up a used double pumper that needs a rebuild and the holley carb book. is it difficult to build?
it seems like all you do is take it all apart, clean everything and replace what looks to be worn out?
thanks for your help,
carl
Old Jan 27, 2006 | 08:01 AM
THUMPIN455's Avatar
THUMPIN455
Default RE: carb rebuild...
Its not too tough, there are a few differences that can mess things up, like power valve gaskets.
There are 3 different ones and the wrong two will dump fuel at a high rate.
Dont over tighten any screws while putting it together.
Dont use chapstick on the gaskets, just get the reuseable ones.
I would recomend pickin up some clear sight plugs also, they help alot when setting the floats.
An old coffe can works well as a carb stand while you are working on it.
Get a jet tool or a really large flat blade stubby screwdriver, messing up the jets isnt fun.
Take your time follow the book. after two or three of them, you wont need the book so much.
Have fun with it, feel free to pm me if you have any questions while doing it.. Could probably help you on the phone if you really need it.
Old Jan 27, 2006 | 02:00 PM
351foxstang
im sure with the book and all of the information on the internet i should be fine. ill PM you if i have any questions when i finally get to start doing it. if i get in too much trouble with it ive got older relatives and such that i can bring it to for help.
thanks for the help,
carl
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
