2V or 4V
It's both. However, a 4 barrel carb doesn't necessarily throw more gas into the engine until you open the 3rd and 4th barrels. You can get just as much gas mileage with a 4v as you can with a 2v, and sometimes better if you stay off the floor with the gas pedal. Although 4v and 2v (valve) heads use the V to designate, whenever one refers to a 4v engine, they usually think of a 4 barrel (venturi) carbureted engine. A 4 valve head has 32 valves whereas a 2 valve head has only 16. Obviously, the 4V head breathes about 50% better.
ORIGINAL: 6mustang6
It refers to the venturis in the carburator. or barrels as you may have heard. The 4 barrels or venturis throw more gas into the engine, thus if not too much, you get more power.
Does that make the new Mustangs a 0 barrel since they are fuel injected?
ORIGINAL: 6mustang6
smartass.
There will be no barrels. lol. I dont understand why the call the carbs, 2v and 4v. i grew up calling them 2 barrel, and 4 barrel.
smartass.
Soaring... just noticed something.. 4 valve V8 engines have 32 valves, each head has 16 valves. 2 valve has 16 to the V8 and 8 to the head.. just a simple engrish typo bro... I think they knows what ya meant.. Just wanted to clarify
