Engine decoding
Dig this article I found. It will either help or confuse you. I looking for a way to tell if yours was a 2V or 4V motor and I still havent found that info yet. There is the link http://www.classicmustang.com/casting_numbers.htm
thanks. this article does help a little. I was digging more as well and came up with the code basically saying it was a fairlane block. This article explains it a little more. It may still be the original block.
In 1968 the difference between the 4 barrel and 2 barrel was the carb, and the 4 barrel engine had 10:1 compression as opposed to 9:1 with the 2 barrel. Those are the only differences i know of or could find. To get that 10:1 compression ratio they used flat -top pistons, Therefore all the heads are the same as well.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
