Transmission filter??
Old Jan 29, 2006 | 10:23 AM
slickman's Avatar
slickman
Default Transmission filter??
I purchased this new cast alum pan and it came with a new filter. This filter was no way the correct one. It looks like it was a deeper reaching into the pan filter. Can I use a stock filter with this pan? This pan holds two additional qts of fluid. I have attached some pics.
The first pic is of the pan and filter I just got. The next pic is the filter thats in my tranny and as you can see, there not the same. Not sure what tranny thats for but, it not for mine. It looks like its for a C4 that was produced after 1970..
[IMG]local://upfiles/26659/D5E99C4E167044A8A037DEBB5DE17992.jpg[/IMG]
[IMG]local://upfiles/26659/E75599CB477E43A297574DB09A65726C.jpg[/IMG]
Old Jan 29, 2006 | 03:54 PM
BadShoe's Avatar
BadShoe
Default RE: Transmission filter??
The new pan and filter you have is for a 70+ C4. The filter from you car is for an early built C4 which is different. With your deep pan you need to use a deep filter also. I think the late model pan should work if it has the same bolt pattern and I would say an early Bronco C4 4x4 filter is a deep style which should work with that pan.
Old Jan 29, 2006 | 04:12 PM
slickman's Avatar
slickman
The bolt pattern of the pan is the same but, I can't find a deep pan filter anyplace..... HELP......................
Old Jan 29, 2006 | 05:43 PM
slickman's Avatar
slickman
BUMP.... I have my tranny cover off and itching to get it back together...
Old Jan 29, 2006 | 06:35 PM
BadShoe's Avatar
BadShoe
You can use a stock shallow filter with the deep pan, no problem but you won't get any benefit from having a deep pan. I think I would put the old pan on and sell the deep pan on eBay.
Old Jan 30, 2006 | 01:40 PM
slickman's Avatar
slickman
From what I have found out, they do not make a deep pan filter for the C4's dated prior to 1970.. So, it looks like I'm stuck with using the OEM filter. Oh well, I have more fluid with better cooling with the new pan.
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
svfetter
Oct 5, 2015 11:39 AM
wraith777
Sep 28, 2015 10:49 AM
