new 289
Old Jan 29, 2006 | 08:46 PM
Volcom66's Avatar
Volcom66
Default new 289
anyone know were to buy a fairly cheap 289 longblock?
Old Jan 29, 2006 | 08:51 PM
mayh3m's Avatar
mayh3m
Default RE: new 289
shortblock*
Old Jan 29, 2006 | 09:03 PM
Volcom66's Avatar
Volcom66
Default RE: new 289
no longblock( lifters, heads, cam...etc.)
Old Jan 29, 2006 | 09:32 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: new 289
you usually see the 302 block which is the same as a 289 block...differnt size rods i believe.....u could always switch em...i dont see why u woul want to though
Old Jan 29, 2006 | 09:49 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: new 289
The 289 is a short block engine from the 60's era. Long blocks start with the 400 numbers.
The 289.302.351W and 351C were all short blocks.
Old Jan 29, 2006 | 09:57 PM
Volcom66's Avatar
Volcom66
Default RE: new 289
well i know 289 is a small block(short block), but ive grew up with ppl saying longblock meaning build engine with heads, timing, lifters, rods, rockers, oil pan..etc. so thats what imean when i say longblock not the engine size itself...sry 4 the mix up...but anyone know where to get one?
Old Jan 29, 2006 | 10:08 PM
daver's Avatar
daver
Default RE: new 289
you wont find a 289 shortblock from any aftermarket suppliers, it will be a 302, if you want a 289 then look in yer local classifieds er somethin, maybe someone has one they wanna sell you.
Old Jan 29, 2006 | 10:44 PM
mayh3m's Avatar
mayh3m
Default RE: new 289
yea i bought a 302 thinking i'd never find a 289....but guess what i picked up a few days ago for $300, already rebuilt and never installed into an engine bay???
Old Jan 29, 2006 | 11:32 PM
traveler's Avatar
traveler
I ♥ Acer
Default RE: new 289
I might know where there is a 289 and a C4 ...if you're interested I see if it is still around
Old Jan 30, 2006 | 01:04 AM
THUMPIN455's Avatar
THUMPIN455
Default RE: new 289
Shortblock does mean no heads, intake, etc. Its only block, crank, rods, pistons, and sometimes the cam is included. Usually used when refering to reman engines, or when you have the bottom end done and still need to do the top, ie heads.
289's used a different crank and rods. Simply changing the rods doesnt change displacement. If you want the 289 displacement, you can get the crank and rods, buy 289 pistons put them in a 302 block, and you now have a 289. A 302 is just as good, offers a bit more stroke, and a few more cubes. Pretty much everything else will bolt right up to a 302. You can even swap in a 5.0L which after 86 had a roller cam and one piece rear main seal. They require a different balancer and flywheel/flexplate, but otherwise are a bolt in deal. Same motor mounts and accessory holes.
