Noisy lifters. Need advice
Old Feb 2, 2006 | 09:51 AM
68FastbackGT's Avatar
68FastbackGT
Default Noisy lifters. Need advice
The 351W I have in my 68 mustang is making a lot of tapping noise from its passenger side. I assume that this is a lifter or 2 that is not pumping up. The engine has enough oil pressure (40 to 50 psi), so I am assuming it is a clogged or sticky lifter.
Assuming the rest of the engine is in fairly good condition, do you think it would be worth pulling the intake manifold off and replacing some or all of the lifters? Or, is there a different path I should consider?
Old Feb 2, 2006 | 12:22 PM
65GTin GA's Avatar
65GTin GA
Default RE: Noisy lifters. Need advice
I think if it was mine I would pull the valve cover, put each cylinder on TDC and check your valve clearances. That is assuming the rockers are adjustable (don't know 351's that much). Also check all your valve springs and rockers visually for anything else unusual. Have you used a stethoscope (or even a long screwdriver to your ear) to try and isolate the noise?
Old Feb 2, 2006 | 12:28 PM
Sinister Audio's Avatar
Sinister Audio
id try dumping a half quart of tranny fluid in your motor usually the tapping will come right out and if it does just run it down the road a couple times and then change your oil. tranny fluid is a miracle fluid for that.
Old Feb 2, 2006 | 06:36 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Sinister Audio
Mystery oil will do the same. I would be wary of running transmission fluid. Don't know why though.
Old Feb 2, 2006 | 07:29 PM
68FastbackGT
Thanks for the advice. Next chance I get, I will pull the valve cover off and inspect the valve train. If all looks good, I will try an oil additive before I disassemble anything else.
What is Mystery oil and where can I get it?
Thanks.
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
