Replacing the manifold
Old Feb 6, 2006 | 06:26 PM
michaeldoggrell's Avatar
michaeldoggrell
Default Replacing the manifold
Quickie: do i need to pull the distributor out when I change my stock manifold into a Torker 2 ?
Or can it be done with the distributor in place?
Old Feb 6, 2006 | 06:31 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Replacing the manifold
It's easier to pull it. Less problems in the long run.
Old Feb 6, 2006 | 06:45 PM
michaeldoggrell
it's easier ok, but is it necessary ?
If its not necessary, i don't really wanna do it because i have to get it running again by monday and i don't wanna mess up my timing.
Old Feb 6, 2006 | 06:53 PM
67t5ponycoupe
You should be able to get a good idea by leaving the distributor in while you pull the old manifold. I would take the thermostat housing off. The new manifold should not be that much different by the distributor. The biggest problem will be making sure the gaskets don't shift when you put the new one on.
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
uberstang1
Sep 20, 2015 06:42 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
MusicCity615
Sep 12, 2015 07:05 AM
