NEED HELP COOLING MY ENGINE!!!
ya thats what your gonna need, new radiator, the two rows are crap. also go with about 175-180 theromostat. dont go too low tho (tho it would seem logical) cuz the engine will run like crap. these car actually run well and need to b pretty warm but not to warm as youve found out
Well, I just checked and it doesn't look like I have the 'stock' radiator, cuz there are three rows. The small slits look fairly clean without any sediment or clogs. A friend of mine mentioned that I may need a new radiator cap... could it be something this simple?? At any rate, I'm gonna flush it, clean it and refill the coolant and get a new cap. Hopefully that will take care of it, if not I will replace the thermostat. What would be a good coolant/water mix ratio? I live in Phoenix where it's around 70 degrees in the winter (high temp), but will get very hot in the summer. Is 50/50 okay, or possibly more water than coolant? Thanks.
ORIGINAL: bartak59
...A friend of mine mentioned that I may need a new radiator cap... could it be something this simple?? ...What would be a good coolant/water mix ratio? I live in Phoenix where it's around 70 degrees in the winter (high temp), but will get very hot in the summer. Is 50/50 okay, or possibly more water than coolant?
You'll get the most cooling from water; so if there's no danger of freezing, go with 100% water. But you certainly don't need as much as 50% anti-freeze in Phoenix. Go ahead and add a bottle of a product called "Water Wetter." It lowers water temps by 10 or 20 degrees. You'll find it at most auto parts stores.
ORIGINAL: Dan66
Yep - a worn-out cap can cause a load of problems. They're kinda like hoses: replace them every couple of years even if you think you don't need to.
ORIGINAL: bartak59
Ok, I'm gonna work on the car over the weekend and I'll let you know how it turns out. Thanks for the tips, and I will definitely use some of that Water Wetter additive as well. Thanks...
ORIGINAL: Soaring
...I still say you need some anti-freeze in your cooling system. Obviously, 100% pure water will cool better than a mixture, but your water pump bearing will wear out sooner...
Galactic
Apr 29, 2019 02:56 PM
Sep 1, 2015 08:16 PM
