Roller conversion
Old Feb 13, 2006 | 10:07 PM
angcobra's Avatar
angcobra
Default RE: Roller conversion
I'm glad I could save you from some pain of learning that the hard way.
Old Feb 14, 2006 | 11:42 AM
hutchamatic's Avatar
hutchamatic
It will work. You must use a Comp Cam for this. They have a special grind with a reduced base circle for the non-roller block. You will also have to drill your block for the hold down bolts of the spring plate retainer. Call Comp Cams and they help you with this complete change over. If you don't use the special base circle the lifters will be to far down in the block.
Old Feb 14, 2006 | 11:53 AM
angcobra's Avatar
angcobra
ORIGINAL: hutchamatic
Actually if you don't use the reduced base circle cam, the lifters will be to far up in the block (out the top of the lifter bore). Have you priced those cams? There are not many cam options for the reduced base circle cam. Also, with all the block splitting issues of the stock block, I'm not sure it would be a good idea to add threaded holes in the valley area. The roller block has a casted boss where retainer is bolted down.
Old Feb 14, 2006 | 07:02 PM
hutchamatic
That is right. I had a brain fart. It has been sometime since I did this. The old blocks are stronger than the new ones though.
Old Feb 15, 2006 | 12:43 AM
69mach1377's Avatar
69mach1377
Just get the Crane conversion kit...
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
uedlose
Sep 30, 2015 08:01 AM
Tyoung68
Aug 25, 2015 04:31 AM
