Transmission question
Old Feb 12, 2006 | 09:11 PM
tylerdru's Avatar
tylerdru
Default Transmission question
What happens if you overfill the transmission with fluid? is there lik an over fill tube? I ask this because we poured in about 5 1/2 quarts of fluid, and then it start leaking like crazy from some where on the driver side. It was not from the gasket. The dipstick said we had too much fluid in there.
Old Feb 12, 2006 | 10:53 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: Transmission question
There is usually a blow off valve to let extra fluid out of the trans. It still won't take it to the level it needs to be at though. It also makes a really big freaking mess. I'm sure you know all about that now!
Old Feb 12, 2006 | 11:01 PM
tylerdru's Avatar
tylerdru
Thanks. I am just happy that the pan wasnt leaking. Yes there was a mess, but there was cardboard under the car.
Old Feb 13, 2006 | 01:13 AM
67t5ponycoupe
You should still drain the fuild out until you get to the proper level. That means dropping one corner of the pan.
Old Feb 13, 2006 | 02:59 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
did u check the level with the car running i have to ask?
Old Feb 13, 2006 | 08:21 AM
tylerdru's Avatar
tylerdru
No i didnt check it running. Yes i know i need to take some out. HOw do you take one corner of the pan down? Last time it was stuck to the transmission so i just yanked it off and dealt with the mess.
Old Feb 13, 2006 | 11:13 AM
stangsrdashit's Avatar
stangsrdashit
Tyler, you have to check the tranny fluid when the car is running and warm. Take it out for some normal driving and bring it back, then check the fluid. The fluid expands when it gets warm.
Old Feb 13, 2006 | 01:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
After you run it in gear, and it still appears to be overfilled, you can take the tranny cooling line loose and drain some of it. Get a rubber hose that is about the size of the tranny cooling line and attach it with a clamp. Then run the fluid into a bucket. If you don't have a cooling line, then loosen one corner of the pan and let it drip. However, I doubt you have too much fluid in it. Take it around the block before you drain any.
Old Feb 13, 2006 | 02:44 PM
67t5ponycoupe
That cooling line thing is a great idea. I had never thought of that.
Old Feb 13, 2006 | 05:32 PM
tylerdru's Avatar
tylerdru
Well, there was fluid in the dipstick so should i just let a little out any ways?
