289 to 347
Old Feb 18, 2006 | 12:09 AM
troysai's Avatar
troysai
Default 289 to 347
I am removing my 289 and replacing it with the 5 liter 347, fuel inected. CAn anyone give me pointers as to matching the tranny, pressure plate, and any other pointers I amy not realize?
Troy
Old Feb 18, 2006 | 12:14 AM
6mustang6's Avatar
6mustang6
Default RE: 289 to 347
Lets see, take that 289, bore it, and put a 347 stroker kit in it. Then get a holley Fuel injection system. BIngo, same original engine, but a FI 347.
Old Feb 18, 2006 | 12:23 AM
troysai's Avatar
troysai
Problem is I threw a piston and the heads and block are trashed. Sounds as if the engines are compatable...
Troy
Old Feb 18, 2006 | 12:30 AM
6mustang6's Avatar
6mustang6
oh, damn. that sucks. i think as far as it bolting to the transmission, you should be ok........... i think.
Old Feb 18, 2006 | 01:07 PM
1965MustangFastback's Avatar
1965MustangFastback
A 347 made out of an old style block or a newer 302 block? If its a newer block and you have a 4 speed and I assume you do because you're asking about pressure plates
you're going to need a special bracket to use with the Z-bar. I looking into getting a 331 stroker and I was told if you use an older block you wont need it, but if you buy a newer block you'll need this bracket.
uberstang1
Dec 7, 2017 07:10 AM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
ryland
Sep 13, 2015 12:35 PM
