Guide plates
Old Feb 20, 2006 | 05:45 PM
slickman's Avatar
slickman
Default Guide plates
Whats the purpose of guide plates? The Edelbrock heads I'm getting has this built in, I just need to get them.
Old Feb 21, 2006 | 12:33 AM
65GTin GA's Avatar
65GTin GA
Default RE: Guide plates
So do Trick Flow Twisted Wedge heads (which I chose), the guideplates keep everything aligned for roller rockers. Be sure to use hardened pushrods for use with guideplates.
Old Feb 21, 2006 | 01:04 AM
slickman's Avatar
slickman
Ok, with that said the Edelbrock heads must be able to use roller rockers and they also must know what brand to use. I'm going to call them in the morning..
ORIGINAL: 65GTin GA
Old Feb 21, 2006 | 01:05 AM
slickman's Avatar
slickman
I was told these would work on a Edelbrock 302 head. Roller Rockers
ORIGINAL: 65GTin GA
Old Feb 21, 2006 | 01:16 AM
65GTin GA's Avatar
65GTin GA
Most any right sized rollers will work on Edelbrock heads - the problem is clearance inside the valve cover. After much research I chose the Trick Flows because they make matching rollers for them (I ordered them) and because Trick Flow Twisted Wedges are raised .350 along the valve cover rim for clearance with my stock height Cobra covers. Problem solved for me and I like not having hassles, LOL.
ORIGINAL: slickman
ORIGINAL: 65GTin GA
Old Feb 21, 2006 | 02:19 AM
Magiarn71's Avatar
Magiarn71
ORIGINAL: 65GTin GA
Don't they also keep everything alligned for non-rollers? Had them in a stock 86 5.0 and it was roller lifters, but not roller rockers....
Old Feb 21, 2006 | 02:33 AM
65GTin GA's Avatar
65GTin GA
ORIGINAL: Magiarn71
ORIGINAL: 65GTin GA
Guess so - sounds good to me..
Old Feb 21, 2006 | 08:29 AM
slickman's Avatar
slickman
Ok so, it sounds like the OEM Hipo valve covers I have will be toast when I install these new heads.. Dam!!
ORIGINAL: 65GTin GA
ORIGINAL: slickman
ORIGINAL: 65GTin GA
Lethaldosage423
Oct 19, 2015 12:12 AM
Explosive
Oct 2, 2015 07:45 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
Sep 25, 2015 06:30 PM
