DIY Caster
Old Jan 6, 2011 | 06:48 PM
001mustang's Avatar
001mustang
Default DIY Caster
Level car.
Sit car on turntable.
Take camber measurements at 20* right and 20* left.
Calculate caster w/ googled equation.
Caster (deg) = (180 / 3.1415) * [(camber1 - camber2) / (turnangle1 - turnangle2)]
Shortcut for Caster w/ 20* turns:
Caster = 1.432 x (camber1 - camber2)
Attached Thumbnails DIY Caster-aster.jpg   DIY Caster-aster-1-.jpg   DIY Caster-aster-2-.jpg
Old Jan 16, 2011 | 12:18 PM
001mustang's Avatar
001mustang
Default Road trip
I took road trip to test DIY alighnment.
67 mustang w/ manual unisteer rack.
DIY settings:
Camber = -0.7, -0.7
Caster = +4.2, +4.36
Toe = +0.11 toe in
Goal: 70mph stability
Test 1: grooved bridge I-75 MM 72 Loudon.
Car used to tram line over this bridge but did fine this trip.
Test 2: Straight line tracking at 70mph.
Car used to wonder but now firmly tracks straight ahead.
Had this car for decades; it has never tracked this well.
Result: The high speed stability and return to center is perfect w/ above DIY settings. Low speed steering effort is a bit hard but ok for me.
I would not run more than 4 caster w/ manual rack. Lower caster reduces low speed steering effort at expense of straight line tracking.
Old Jan 16, 2011 | 01:31 PM
chris66dad's Avatar
chris66dad
I did my own alignment also but "only" went to +3.0 caster on both sides. Car tracks and handles great at speed. At very low speed you will get Popeye arms trying to turn manual steering.
Write up and info here: http://chris66dad.tripod.com/id27.html
Old Feb 23, 2011 | 01:59 PM
001mustang's Avatar
001mustang
I installed 1/16" shim on front UCA bolt (driver and passenger side) to give me a head start at increasing caster while minimizing LCA stress.
Old Feb 26, 2011 | 04:37 PM
pappastang's Avatar
pappastang
i tried to look at your attachments, it says i dont have permesion ? how do i get it.
i do have a account for this site thanks
vargas
Jun 17, 2017 12:17 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
winner99
Sep 30, 2015 07:04 PM
Luke9222
Sep 4, 2015 06:46 AM
