Convertible Top Leaking
Old Mar 20, 2007 | 08:16 PM
South NJ Stang's Avatar
South NJ Stang
Default Convertible Top Leaking
Alright, well back in october I aquired a 2001 Cobra Convertible and its a great car I love it, only problem it has 94,000 miles on it and the previous owners definetly beat the hell out of this car. So far I have fixed most of the problems, but one major problem still remains. Whenever I wash the car, it rains, or snows, the bac of my car turns into a swimming pool. Behind the back seats in that little spot where the top goes into (I don't know the name of it) fills with water, and the trunk of the car on the passenger side becomes soaking wet. I know that the leak is on the passenger side behind the back seats. My question is, how hard is it to fix this? Someone told me there is a spray silocon that I could use to fix it. It doesn't seem to be a very large leak but its enough to flood my car. I would really appreciate the help because the garage I keep the car is getting renovated and the car will be outside for a few weeks and with my luck it will rain every day.
Old Mar 20, 2007 | 08:28 PM
StagHunter's Avatar
StagHunter
Default RE: Convertible Top Leaking
ORIGINAL: South NJ Stang
It's called the stacking well.
Sorry to be the bearer of bad news, but I doubt the fix will be so easy as spraying something from a can onto it. When my 1994 convertible had a similar leak, it was due to the fabric that sealed the back window rotting out. If this is the case, the back window needs to be replaced, most likely along with the top. I put this off for a while by keeping a towel rolled up in the bottom of the well which I would squeeze out and dry after every rain, but eventually I had to bite the bullet and choke up the cash. Since you're in NJ I'll refer you to my favorite top shop; Asbury Auto Tops on Asbury Ave, Asbury Park. Very old shop, very good work, reasonable prices.
Old Mar 20, 2007 | 08:31 PM
dupontjm's Avatar
dupontjm
My 99 was doing that..No matter how I tried to get it stopped the well filled with water...The glass portion of top was shot..I got a new top and "backlite" ...and had a local guy install it and ZAP no more leaks..You can buy just the backlite with glass in it if the top is in otherwise good shape..
Old Mar 20, 2007 | 11:20 PM
South NJ Stang
I heard from a few people that the top would need to be replaced. Ugg I don't have the cash for that. Right now I have a towel wrapped around that area and its been working so far. Thanks for your imput guys.
Old Mar 21, 2007 | 12:26 PM
TwotoneVert's Avatar
TwotoneVert
Have you checked to make sure the drain holes are not plugged with trash. If it is pooling up, sounds like it has not where to run. I can understand it getting wet and damp, but you should not see any pooling of water. Find the drain holes and clean them out, it may help until you get the back window, top, or both replaced.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
dalefrancis88
Sep 11, 2015 07:15 AM
