lowering mustang
Old Jun 13, 2007 | 09:10 PM
john quez's Avatar
john quez
Default lowering mustang
Hello,
Whats the best way to lower my stang about 1 1/2 inches.
Old Jun 13, 2007 | 09:11 PM
jacrockett's Avatar
jacrockett
Default RE: lowering mustang
Springs.
Eibach Sports will do the trick just fine.
Old Jun 13, 2007 | 09:32 PM
undecided.steve's Avatar
undecided.steve
ORIGINAL: john quez
Hello,
Make certain you get springs for a vert.....
This is very important, because the spring rates are different than for a coupe.
Eibach sells a separate kit for the vert.
Old Jun 13, 2007 | 10:29 PM
hot wheels's Avatar
hot wheels
H&R! too many complaints about eibach springs unless you go with the sportlines. do a quick search and you'll see all the sagging and uneven comments about eibach.
Old Jun 14, 2007 | 02:36 PM
undecided.steve
ORIGINAL: hot wheels
+1
Does H&R make a set specifically for the vert though?
I'm not sure.
Old Jun 14, 2007 | 06:53 PM
hot wheels's Avatar
hot wheels
they must, when i ordered my supersports they asked if it was a vert or that other enclosed one [8D]so i got the ones for my vert. just make sure you specify which ones you want. you can't go wrong with H&R!
Old Jun 18, 2007 | 04:44 PM
Stkjock's Avatar
Stkjock
Retired Mod
the steeda sportlines are terrific on the vert as well.. car sits really nice IMO and ride is good
Old Jun 19, 2007 | 06:36 PM
sixt5's Avatar
sixt5
the ford racing G springs lower 1.2 inches in front and back.
Old Jun 28, 2007 | 07:10 PM
Slate's Avatar
Slate
It depends if you want it tight enough to race or if you want a bit more of a comfortable ride.
My first mod was 20" wheels and tires. The low profile tires made the ride stiffer because there is not as much spring in the tires. Then I wanted to lower the car but I didn't want to give up any more of the comfortable ride. I'm not racing so comfort is an issue and I didn't want to feel like I was driving a skateboard. I browsed the various forums and received some advise. I ended up going for the Steeda "Ultra Light" Lowering Springs with Tokico D-Spec Adjustable Shocks and Struts. This lowered the front by 1" and the rear by 1 1/2". At the same time, I added a Steeda Strut Tower Brace and a Steeda G-Trac Brace.
Well, the results were fabulous!! In my opinion, the car looks far better lowered. I don't seem to have lost any more of the comfort in my ride and the car handles remarkably better. It sits straight in the corners with no body roll and it stays down while in corners over a bit of rough road - no more front end shifting to the left or right on bumpy corners.
The Shocks & Struts are easily adjusted and can be tightened up at the trackfor those who want to do a few laps. Then back to a softer ride once your done.
The Tokico D-Spec are pricy but, they did what I wanted them to do so it was well worth it for me.
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
dseg
Aug 8, 2015 09:00 PM
