89 CONVERTIBLE NO POWER !!!
Old Mar 3, 2008 | 09:21 PM
89MUSTANGCONVERTIBLE's Avatar
Default 89 CONVERTIBLE NO POWER !!!
I have a 1989 convertible that dont go up or down. I checked the fuse in the fuse box and it was good.I used a multimeter tocheck the circuit breaker with the ignition in the "ON " postion and still had no power.I removed the back seat and hard wired the convertible motor and the top went up and down, so therfor I know the motor is good. When I press the convertible button a I dont hear anything "No relay or motor noise". I removed the convertible switch and check for constant power "12 volts" and I had nothing. I also replaced the switchwitha new one . I know the two relays in the back by the motor only control the top to go up and down, but my top dont do either. Is it possible that both relays burnt in one shot, or is there a fusiblelink in the motor compartment. Dont forget that my car is a 1989 and dont have a breaker or fuse box in the engine compartment. Any help whould be greatful. Thanks,
Brian Air-Repair@hotmail.com
Old Mar 4, 2008 | 10:34 AM
Default RE: 89 CONVERTIBLE NO POWER !!!
Can anybody help me out with any suggestions. Thanks, because I'm stumped
Old Mar 5, 2008 | 11:01 AM
Old Mar 9, 2008 | 07:00 PM
thrty5thsc's Avatar
thrty5thsc
The switch or the relays may be bad.Try the switch first. there is one relay for up and one for down so, I don't think they would both be bad.
Old Mar 9, 2008 | 09:21 PM
Hi thrty5thsc,
Thanks for the reply. I already replaced the switch with a new one, but no luck. I was wondering if there is a fusiblelink in the engine compartment. Thanks
Old Mar 12, 2008 | 08:13 PM
Any one else have a suggestion with something else that I can do. Thanks
Old Mar 14, 2008 | 05:37 PM
Spring is near...............with a convertible and no top
Old Mar 18, 2008 | 08:15 AM
HELP SOMEBODY
Old Mar 22, 2008 | 10:41 AM
FIXED. Ran new power wire from hazard switch to convertible switch. The wire from the fuse box to the switch had a short.
GPR
Dec 16, 2015 12:21 PM
unit91
Sep 15, 2015 09:53 AM
Mikett
Sep 12, 2015 10:52 PM
dalefrancis88
Sep 11, 2015 07:15 AM
spamedic
Sep 9, 2015 12:15 AM
