Fox drop top doesn't drop
Old Jun 9, 2008 | 08:13 PM
Ernie in KY's Avatar
Ernie in KY
Default Fox drop top doesn't drop
Hello everyone. I recently bought an 88 GT convertible. The guy I bought it from said the top doesn't work but you can jump the relay with a wire and make it work. I would like to figure out the problem and fix it properly. He has replaced the switch. When you push the switch nothing happens. No click, no motor noise, nothing. When you pull it the motor runs but the top is already up, it seems like it's working in that direction though. I swapped the relay, no luck. Any suggestions? Wiring diagram?
Also, is there any kind of "proper" procedure for lowering the top? Does it have to be running or in park or anything? Thanks!
Ernie
Old Jun 13, 2008 | 08:51 AM
ewgoetz's Avatar
ewgoetz
Default RE: Fox drop top doesn't drop
far as procedure for lowering the top, you should be at a dead stop. on the 94's and up you need to have the parking brake up to lower it.
I think it's best to have the car running also but not nessessary.
Old Jun 16, 2008 | 05:59 AM
Ernie in KY
OK Thanks. Now if my switch only worked...
I put it down by hand the other day, I just couldn't wait any longer.
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
uedlose
Sep 10, 2015 03:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
zanemoseley
Sep 6, 2015 12:58 PM
