Convertible window replacement
Old Dec 18, 2008 | 03:27 PM
hangtown red's Avatar
hangtown red
Question Convertible window replacement
After trying to search for questions about convertible window replacement I am now asking for some advice. My "65 convert. has a vinyl rear window that has come apart at the zipper. The zipper attached to the top has come undone. Does this require removing the top so that it can be resowen? If I want to replace the old vinyl for a new vinyl is that also a do-it-yourselfer?
Thanks
Old Dec 20, 2008 | 01:08 PM
hangtown red
I can't believe that I am the only mustang with this problem. So how did you solve your problem?
Old Dec 26, 2008 | 12:07 PM
noroof66's Avatar
noroof66
The shop manual has some good pictures showing replacement. You do not have to remove the top, you only have to remove the staples at the rear bow (done outside of car), and at the tack strip (in conv. well) air stapler is main tool you need to staple the zipper portion to top bow, and bottom portion to tack strip.
Roger Mabry
Jun 15, 2016 08:27 AM
importsmasher
Oct 9, 2015 04:42 PM
Calizic
Aug 28, 2015 01:46 PM
Mustang Sally72
Aug 11, 2015 07:54 AM
vbonina
Aug 6, 2015 02:56 PM
