window hits top
Old May 24, 2010 | 11:54 AM
mike 1967's Avatar
mike 1967
Default window hits top
Hey folks, I have a 99 which we just bought and the top seems to be to far to the drivers side and catches the window when in the up position and shutting the door. Does anyone have a remedy for this? Thanks for any help!
Old May 25, 2010 | 08:41 PM
GreyStang's Avatar
GreyStang
Can you post a pic?
Sounds like something is loose broken or bent in the tops hardware..
Old May 25, 2010 | 08:44 PM
socalwrench's Avatar
socalwrench
You should be able to adjust where the glass sits in relation to the window regulator; and bring it down.
Old Jul 21, 2010 | 02:34 AM
lpcard's Avatar
lpcard
My sister's 2000 has the same problem, where the top folds directly over the middle of the driver's side window is sagging. If you hold it up while you roll up the window it rolls up just fine. She's having an upholstery shop or a body shop look at hers.
cr620
Oct 3, 2022 10:18 PM
b8checker
Oct 8, 2015 12:55 PM
Sep 30, 2015 12:39 PM
wraith777
Sep 28, 2015 10:49 AM
