What Type Metal???
Old Aug 27, 2010 | 10:46 PM
unit91's Avatar
unit91
Cool What Type Metal???
What type of metal was the top frame made out of in 1968? I have a split in the metal that needs repair. It's the part of the frame that the clothes hanger hook is on.
Old Sep 1, 2010 | 01:44 PM
unit91's Avatar
unit91
Whitish metal, black on outside. ???????
Old Sep 1, 2010 | 11:53 PM
Meester_Vapor's Avatar
Meester_Vapor
I'd say the early metal was the best.
The genre was created by Rob and Priest probably with British Steel. Take that into the middle 80's and most metal had lost it's soul.
Megadeth never fails to make me grin, and Priest is still screaming. Some have morphed over into experimental rock, like Soulfly...
I think real metal died in the 80's.
Old Sep 4, 2010 | 09:45 AM
unit91's Avatar
unit91
WTF................over................
Old Sep 4, 2010 | 10:07 AM
JIM5.0's Avatar
JIM5.0
ROFL! I thought I was too hung-over to be entertained much this morning, between this an another post I just read, you all just made my day!
Old Sep 5, 2010 | 07:37 PM
scan1959's Avatar
scan1959
Unit91,
That is "pot metal". We sometimes hear it called "monkey metal", but mostly it is just cussed at.
Pot metal is used on all the cast arms in the quarter panel at the ends of the back seat, and at the very front(header piece). The bows that join one side to the other over the top of your head are steel.
Very few decent welders will even try to weld pot metal. It is cheap to cast, but made mostly of zinc.
Good luck!
scan
Old Sep 7, 2010 | 10:50 AM
unit91's Avatar
unit91
Can you heat this stuff and then bend it back while hot before bracing it in some manner? Or will it break? Thanks.
Old Sep 7, 2010 | 11:21 AM
scan1959's Avatar
scan1959
I don't think you can do anything with it like that.
Pot metal oxidizes as it gets old, so trying to heat it up and do anything with it is pretty much a nono. It will even have air bubbles in it on the inside sometimes. It was used by all car makers because of the low temperature needed to heat it to in order to cast the part.
I see the oxidation problem at the front header frequently. There will be "bubbles" like it has rust under the paint. Scrape away the paint and there is a bunch of dust where the metal is oxidized and just a pit where there used to be metal.
The newer Stangs don't have as much of a problem with this phenomenon.
Good luck
Old Sep 8, 2010 | 11:44 AM
unit91's Avatar
unit91
roger that.........thanks
Old Sep 21, 2010 | 06:34 PM
alfred9744's Avatar
alfred9744
what about agood cleaning and some liquid steel or other metal epoxy seen a guy who fixed a gouge on a axle shaft and i used it many times on an old harley,held the oil pump 2gether
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
mrappe
Sep 26, 2015 10:16 AM
