convertable top
Old Sep 26, 2010 | 11:23 AM
mustangmike69's Avatar
mustangmike69
Default convertable top
I have a 2005 Mustang Conv. The back glass has come unglued from the top, the window is still attached to the inner linning of the top! Can anyone tell me if the back glass has to be replaced, or if the entire top has to be replaced! And can someone give me a ballpark figure of what that should run me both parts and labor! I have had one upholstry shop tell me that the back glass had to be replaced, and onr glass shop tell me the entire top had to be replaced! kinda backwards, I know! Someone please send me in the right direction! Thanks
Old Sep 26, 2010 | 02:03 PM
scan1959's Avatar
scan1959
Mike,
I am a professional convertible top installer:
Here's the straight scoop. On the older Mustang's(94 to '04) the back glass could be replaced withhout replacing the convertible top.
The newer 'Stangs have a convertible top that doesn't have a separate back window which can be changed out without changing out the whole top.
What I'm trying to tell you is that the whole convertible top needs to be replaced. Here in Central Florida, that job including a high quality convertible top and labor to install is in the range of from $1500 to $1800. That is fvor a top of the line Robbins top and labor included. Make sure that your quote is "Robbins" and make sure that the quote has the original Heater/Defroster back window.
Good luck.
Old Sep 26, 2010 | 03:28 PM
mustangmike69
Originally Posted by scan1959
Mike,
Good luck.
Thanks man! Just wanted to verify that the top did infact need to be changed! It's 5 years old so I won't be replacing a "good" top! I also thank you for verifying the cost as well! My insurance wont cover the top because it wasn't "sudden and accidenta",the extended warrenty doesn't cover converable tops, go figure, so it'll come out of pocket 100%. Thanks again for the info!
chrisdbassplayer
Oct 13, 2015 06:53 PM
folivier
Oct 2, 2015 05:34 AM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
folivier
Sep 26, 2015 02:28 PM
