scoops
Old Mar 23, 2004 | 09:39 PM
gdg1006's Avatar
gdg1006
Default scoops
Is there any type of kit out there that lets you make the hood and side scoops functional. Other than the Mach 1 conversion kit I can't find anything. I just cant get used to the fake scoops on my 99 GT. If there aren't any conversion kits is there anything you can do to make them look better.
Old Mar 24, 2004 | 12:12 AM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
Default RE: scoops
There is nothing you can do to make them functional. You can get some inserts to make them look better though, do a google search, that should help.
Old Mar 25, 2004 | 02:19 AM
gdg1006's Avatar
gdg1006
Default RE: scoops
The only thing I have found are stainless steel inserts and aluminum side scoop inserts. Are there any aluminum hood scoop inserts for the 99 GT.
Old Mar 27, 2004 | 04:40 PM
MelloYello's Avatar
MelloYello
Default RE: scoops
The side scoops for any model 94 + are functional...... if you look under your wheel well in the rear you have vents that lets air circulate through the wheels for brake heat etc.... Wih the side scoops they help capture more air to throw through them vents.....
A little advice Ive had a several pair do not use the double sided tape they issue with them... unless you want to fork out another 80 bucks.... Use a fiberglass glue or try epoxy........ whenever you want them back off itll take the paint with them but hopefully youll want to leave them on.....
Oh yeah att: Californians!!!! If you see some yeller side scoops near San Bernadino there MINE!!!!!!!!!!!!!!!!! lol (100mph winds blow them lil suckers right off) lmao
Mel
P51_GT
ROUSH Performance
24
Apr 6, 2019 09:19 PM
PaulH2
20
Jan 31, 2016 09:48 AM
GentleBen
Sep 11, 2015 05:34 AM
kdryan
Aug 21, 2015 04:01 PM
MustangHead91
Aug 16, 2015 03:20 PM
