Wet sanding
Old May 9, 2006 | 11:40 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Wet sanding
If I wet sand a few spots with really fine paper will it buff out nice by hand and compound
Old May 10, 2006 | 04:04 AM
hwest's Avatar
hwest
Default RE: Wet sanding
Before you wet sand try using polishing compound by itself first if that doesn't work then go to buffing compound and as a last resort go to the wet sanding.
Old May 10, 2006 | 10:07 AM
Scott P's Avatar
Scott P
Haze left behind by wetsanding often requires heavier compounds and a rotary polisher. What are you trying to wetsand?
Old May 10, 2006 | 11:01 AM
Color by WEASEL's Avatar
Color by WEASEL
Use 2000 grit to remove orange peel or other surface imperfections. If all you have is dull, or minor scratches, do not sand. Get a good rubbing compound. 3-M Finesse is a VERY good product. Not like turtle wax or other "store brands" that go on heavy and are hard to remove. 3-M Finesse is creamy smooth, good cut, and comes off easy. With a buffer as it heats up you can actually see it go on, do it's job and come off, all in the same motion. Buff it off and hit it with polish. Then, wax or glaze depending on your preference. I like glaze, but only because everything I do is scratch and swirl free first. I am not "filling" blemishes, I am making the surface shine. I do custom paint and everything I put out looks wet! See http://colorbyweasel.com to see for yourself. I specialize in flames and graphics on high dollar motorcycles. Good luck!
[IMG]local://upfiles/36686/64BD728119A047B199823E79A2D9407A.jpg[/IMG]
Old May 10, 2006 | 02:31 PM
ByPopularDemand
ORIGINAL: Scott P
Some overspray from hell that woulnt come off
Old May 10, 2006 | 02:41 PM
Color by WEASEL
I would use rubbing compound or polish and like someone else said, sand as a last resort. It will be "frosted" when you sand it but it will come back. Use 2000 dry and you can see it work before you cut too deep. Again, I would still buff it first.
Old May 10, 2006 | 03:53 PM
laserred38's Avatar
laserred38
Did you try TR3?
...BTW...popular did you ever tell us what you were doin when you got the overspray on your car?...just curious
Old May 10, 2006 | 04:51 PM
ByPopularDemand
Painting random stuff black with duplicolor spray paint
Old May 12, 2006 | 06:15 AM
hwest's Avatar
hwest
ORIGINAL: Color by WEASEL
+1 Very good advice!!! I honestly cannot say enough about 3-M products, they are awesome!!!
importsmasher
Oct 9, 2015 04:42 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 8, 2015 11:50 AM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
NeoTokyo
Apr 11, 2004 12:57 PM
